Where do I buy hinge pins for an Austin big seven I recently drilled one of mine out as it was extremely stiff with years of rust that no amount of soaking in oils would fix.
I cant seem to find any.
07-05-2020, 12:45 AM
(This post was last modified: 07-05-2020, 12:46 AM by Ian Williams.)
Re-pin it with a slightly oversize pin
They would be easy for someone with a late to make for you.
