12-08-2017, 04:47 PM
(This post was last modified: 12-08-2017, 04:49 PM by Erich.)
I have coil and battery, so this is not about Austin 7s. On another forum, selling a Matchless with a magneto, a poster has said that retarding the spark is not necessary and in fact that the magneto produces a weaker spark when retarded. I always retarded the spark on my motorcycles to avoid kick back. But more importantly, I don't see how retarding the spark would weaken it. Shouldn't the mag produce a consistent spark but retarding just causes the spark to occur at a different point in the engine's cycle?
Erich
In electrical theory , the faster the magneto turns the fatter the spark will be .
Merv
Thank you all for the responses. This helps to explain on the other site that retarding the spark does not diminish it enough that it isn't desirable to start with the spark retarded.
15-08-2017, 06:41 AM
(This post was last modified: 21-08-2017, 09:47 AM by Bob Culver.)
For motor bikes the range between kick start and full advance may be 40 crank degrees, but the necessary spark range for a non racer Seven is only about 15 crank degree, so unlikely to stray much out of the optimum range
Not really relevant or analogous but the curious may be interested that the advance range of the LT magneto on a Model T extends beyond one pole, so there is a narrow advance band between poles where the car will not run on the flywheel magneto. The driver learns to avoid this.
