Hi Youngseven
You’ll get lots of responses from others more knowledgeable than me but here goes...
The brake pedal lever seems quite large diameter (I don’t think it’s a standard lever) and is offset from the pin. The lever should be quite close to the steering box. This has necessitated the odd brake actuator rod. This should be straight! Bent like yours it will deflect and make the brakes feel less than hard. The steering side tube seems a little long but that might be the way the pic has been taken. Interesting spring on top of the track control arms!
Hope this helps
Usually the opening chorus is, put a David Cochrane steering arm on it right away. This time, however, it is difficult to know what to say about that brake rod, other than to find it difficult to imagine anything worse. Well done for showing the pictures and asking for advise, things will get much better from here on.
Somebody has been solving problems they themselves have created as they go along, and ended up with a horrible final set up.
We have all done it, most of us have realised it, taken it apart, and started again.
Which I would do in this case.
The brake operating rod MUST be straight, the steering arm coming out of the steering box should be more or less vertical.
Start from there, and solve the new problems it gives you.
Simon
Hi, I would be inclined to get a new steering box housing from David Cochrane and do away with The WEDGE, Which is what is causing the problem.
COLIN
NZ
Thankyou all for your replies, they are very helpful. Just to confirm the drag link needs to connect on the inside of the steering box arm not outside. With the drag link is there one set Length for all sevens.
I never understand why when fitting a wedge people don't keep the brake pedal in it's original location, it solves all those problems and requires very little more fabrication than making the wedge did in the first place. I would not drive a car with a brake rod that had been altered in such a way, your life depends on this rod! Colin is of course quite correct and the best solution is one of Davids steering boxes.
Car type: Austin 7s
Its a very late chassis fitted with an early steering box, probably in a random position.
Check the length of the steering tube.
Set the front wheels EXACTLY straight ahead.
The steering tube and the steering box drop arm should now be at 90 degrees.
