25-04-2020, 08:07 AM
In the past I've welded two cut down tubes with a 3" scarf join to the required length. If I was to need another I'd nowadays make new.
Steering column wedge - problems with the sterring arm going over...
25-04-2020, 08:10 AM
Thanks Henry
25-04-2020, 10:53 AM
I'm following this with interest, as I have exactly the same problem as Ruairidh. Lengthening the draglink looked like the best solution. I was considering cutting and sleeving it, perhaps internally and externally, to add another inch.
25-04-2020, 01:09 PM
With a Canbridge wedge I didn't have an over the top problem until I cut off some of the lumps on the track rod arms - which are the stops.
So, if you have an OTT problem, can you not just add a little to these lumps? My wedge has a vertical strip welded to it, drilled for a bolt to go through the original brake pivot hole in the chassis (you need a big washer too, it is a big hole), which gives you back the three pont mounting.
25-04-2020, 03:11 PM
You can add metal to the lumps ( stops ).
But then you will have a 3 mile turning radius. When I built my first ulster rep, I used an ALR wedge. It was so long ago i bought if of Alan himself at a show. I cut as far as I could into the rubber mounted foot on the engine, and mounted the wedge as far forward as I could, it worked fine on a standard draglink. Tony.
25-04-2020, 07:14 PM
(25-04-2020, 03:11 PM)Tony Betts Wrote: You can add metal to the lumps ( stops ).What does it mean in detail? What are lumps and where are they located? I need a small correction of turning radius because the front brake cables touch the tires (4,50-4,75 16") a little bit in endposition.
25-04-2020, 07:59 PM
(This post was last modified: 25-04-2020, 08:00 PM by Henry Harris.)
25-04-2020, 10:38 PM
Thank you Henry for that explanation!
25-04-2020, 11:07 PM
For both of my specials I bought replacement castings made to a reduced angle. They seem to work without problems and it's an easy fix for the centre position of the brake pedal. Perhaps not the cheapest solution but effective...
