29-03-2020, 11:26 PM
Either that or the engine and gearbox are back to front
4 speed clutch release bearing on 3 speed gearbox
30-03-2020, 09:25 AM
30-03-2020, 09:31 AM
Has the starting handle shaft been omitted?
30-03-2020, 09:26 PM
Aha, Dave! Ingenious, with or without the starting handle shaft.
30-03-2020, 10:36 PM
Does one have to use the late clutch toggle posts also?
30-03-2020, 11:01 PM
The clutch toggle posts are all the same unless you are using and Borg and Beck or Newton Bennett type - these use collets but won’t fit in the earlier type clutches.
31-03-2020, 12:29 AM
Thanks. Answers my question.
31-03-2020, 07:24 AM
Hi All
Interesting thread. Do you have to use the hammerhead toggles with this conversion and if so why? Cheers Howard
31-03-2020, 09:05 AM
(31-03-2020, 07:24 AM)Howard Wright Wrote: Hi All here's an engine and gearbox that came in a couple of years ago. The builder had fitted a 4 speed release bearing and kept the 3 speed style clutch fingers. The massive groove in the face of the release bearing isn't as obvious in the photo as in "real life". [/url] in the second photo you can see what's left of the 3 speed fingers as well as some of the metal filings that have come off the setup while the car was being driven.
31-03-2020, 10:01 AM
Hi Stuart
Thanks. I retained the 3 speed levers when I rebuilt the clutch on the special. Seems I am not going anywhere for a while so I will have plenty of time to take the box out and change the levers. Cheers Howard |
