3-bearing engine - Magazine Cover
A clear - if rather perfunctory - sectional drawing of a 3-bearing engine from 1936.
Click the image for a clear version - and click again for an enlargement or to copy.
Is anyone still running the original pattern wide rings? With them oil consumption on my car was for a period  almost nil. When it reached 1 pint in 800 miles my father thought ir was due for overhaul!!
Was there ever an engine wiht a less rigid centre bearing? ThebBig Seven was the other extreme.
Nice picture, thanks for sharing.
Bob, Jack Cotton had a scheme for reinforcing the centre-main and making the 3-bearing crankcase less liable to flex by bolting an aluminium casting to the base of the crankcase where the mesh is usually.
A diagram was in one of the 750 Club Bulletins and is reprinted in "Design for Competition" (1966).
(30-03-2020, 02:53 AM)Ritchie Wilson Wrote: Bob, Jack Cotton had a scheme for reinforcing the centre-main and making the 3-bearing crankcase less liable to flex by bolting an aluminium casting to the base of the crankcase where the mesh is usually.
Would anyone, by chance, have a copy of this which they could post here, assuming that copyright is not a concern?
Jamie.
