backfire through SU and rough running
Just to close this one out, the two contributing problems were a loose tappet and an issue with the points. All sorted now. The Bosch 009 seams to be fine so I am continuing with it but bearing in mind comments from others.
Thanks again for the help.
Cheers, Rod
