Car type: 1929 AD Tourer, 1930 Rosengart LR2, Rosengart LR4 Van 1938 APE Tourer (Opal)
Where did you find this one ?
Super pics. Thanks Mike. Must say, the ladies look a bit, er, formidable...
Renaud ??.
Quite clearly shows the two different radiator surrounds and no sign of the aluminium wheel disc that “all” Rosengarts had, not !
Interesting, Derek. So was the full radiator surround the earlier version, and the ribbon surround later? Perhaps they did all come with wheel discs, but people removed them for competition use?
The earlier had the wider style ( in general, the ability for the French to keep good records of year of manufacture is a bit lacking). The five wheels on my LR2 , two were drilled to fit discs the other three not. They are closed centre type with the Rosengart badge embossed , so quite noticeable when drilled.
