  • 1 Vote(s) - 1 Average
Column change remote
Having succumbed to unreasonable harassment from Ian, Athow and various other "friends" here are some pictures of my variation on a theme. The design was based purely scrap bits had in the shed, a broken gear box lid, steering box, column, and NZ rail spanner.....no salvageable parts were used in the construction.
WOW!!!! And inside the lid ?
Hey that’s nice
Is this what you want to see Tony?
Excellent- did you cast a new cover ? Great work !
Tony, my guess it is a welded joint, I’m sure Joss will confirm, beautiful work, anyone would be very proud to have this on their car.
Hi Joss
Inspirational.
Does the lever reverse the direction of the gate or is there a pivot in the top of the gearbox cover?
work of art. everything fit for purpose and lovely and compact.
Very nicely done! To add to the other questions already posted did you lower the bottom of the notch in the reverse selector?
Robert leigh
That is excellent, a joy to look at. Well done indeed!
