AAK Rear Lamps
Can anyone tell me what the correct rear lamps should be on a 1935 AAK Tourer?
1935 AAK Tourer
According to Purves, it would have had a single Lucas tail light without a stop lamp.
He actually says "Lighting: Identical to the Ruby Saloon headlights and sidelights but the tail light was the earlier Lucas version and did not incorporate a stop lamp".
Rinsey Mills says the Lucas ST38A "Pork Pie" lamp was introduced in August 1933.
Rick
In deepest Norfolk
Thanks. I suppose a pair of pork pies would be the best option. The ones incorporating stop lamps.
1935 AAK Tourer
Either that or pair of D-shaped lamps fit nicely either side of the number plate.
Originally all sevens would have simply had one rear light, I believe modern lighting regulations in the UK will insist on two being fitted today, so provided you use the period style ST38 or D lamp, as already suggested, appearance would not be too wrong.
Good evening. As has been stated the car would have been fitted with a single ST38 Pork Pie lamp. I fit these with one of CRDC LED units which give an excellent 'high level' stop lamp which is more suited to today's conditions. Additionally I fit a pair of Lucas 471 lamps to the wings which again I fit with LED bulbs from CRDC, these lamps are available from Jamie at The Seven Workshop.
Stuart
Thanks for the replies. I've taken them all on board. Smile
1935 AAK Tourer
