06-02-2020, 12:12 PM
Oil Button
06-02-2020, 12:32 PM
Looks like it needs a lot of work!
Here it is back in the mid-1970s: 006.800.jpg (Size: 82.54 KB / Downloads: 304)
06-02-2020, 12:40 PM
(This post was last modified: 06-02-2020, 12:46 PM by Mark McKibbin.)
Thanks for the answers, from the parts book for a 1927 car I need a button that looks like this one and I will get another patent plate (magneto one smaller)
Mark
06-02-2020, 03:50 PM
Here is slightly poor picture of our early'28 layout, with contemporary dash light and underdash lidded cubby holes. I believe the original bits are how yours should be.
Robert Leigh
06-02-2020, 10:46 PM
Measured from my chummy the hole is 8" in from o/s of dash and 4 7/8" up vertically from bottom edge of dash.If you get stuck I could help with a reconditioned round oil button.
07-02-2020, 01:56 AM
You can also with a bit of fiddling get a Lucas SM3 switchboard to operate a coil ignition engine.
07-02-2020, 09:59 AM
(This post was last modified: 07-02-2020, 10:05 AM by Mark McKibbin.)
(06-02-2020, 10:46 PM)Austin in the Shed Wrote: Measured from my chummy the hole is 8" in from o/s of dash and 4 7/8" up vertically from bottom edge of dash.If you get stuck I could help with a reconditioned round oil button. I assume it's centred on the steering column? (07-02-2020, 01:56 AM)Tony Press Wrote: You can also with a bit of fiddling get a Lucas SM3 switchboard to operate a coil ignition engine. I will lookout for an SM3 and give it a shot, I assume the SM3 puts an earth on the maggy to stop whereas the SM5 puts battery on the coil to go. (06-02-2020, 03:50 PM)Robert Leigh Wrote: Here is slightly poor picture of our early'28 layout, with contemporary dash light and underdash lidded cubby holes. I believe the original bits are how yours should be. I like the cubby holes, desperately needed as I don't even have door pockets.
Mark |
