03-02-2020, 11:54 PM
(This post was last modified: 03-02-2020, 11:56 PM by Zetomagneto.)
David, the unrepaired ones also hold out.
Sound advice from Tony.
Scrap block?
05-02-2020, 07:01 PM
The little crack is often a source of a leak which manifest itself by allowing water to go up the centre stud.
It is often thought the head gasket has failed when this happens. I have used gasket goo under the washer on the centre stud to stop the leak as a tempory measure. Tempory as in the same block in use for 20 years until a crack appeared in the side of number one cylinder that is. ( block was + 080 thou ) |
