30-11-2017, 06:02 PM
Dennis,
I've just emailed you at your nippy address.
Jeff.
Jeff.
KING PIN THRUST WASHERS
Dennis,
I've just emailed you at your nippy address. Jeff.
30-11-2017, 06:23 PM
(This post was last modified: 30-11-2017, 07:08 PM by Dennis Nicholas.)
(30-11-2017, 05:16 PM)Stuart Giles Wrote: I have done the kingpins on a few Big Seven axles in the past, and was always lucky enough to pick up period -Thompson, Brivec etc. manufacture kingpin sets to do the work. These did include a bronze thrust washer as well as the hardened steel washer in the package. However, the Bronze thrust washer was never anywhere near thick enough; I assumed that this was due to the recess below the axle eye having worn deeper over the years.Thanks Stuart. I wish I had your knowledge and ability to turn things up on the lathe. Because of my "bit worn" Atlas lathe and my lack of how to really work it (turning speeds, tool shape etc.) I limit myself to turning things that are not critical for size ![]() Dennis Thanks Stuart. Would phosphor bronze thrusts wear the axle faces or would they just wear out themselves? Dennis.
01-12-2017, 01:23 PM
(30-11-2017, 06:23 PM)Dennis Nicholas Wrote: Would phosphor bronze thrusts wear the axle faces or would they just wear out themselves? Can't give a definitive answer on that. The special in my avatar has had a Big 7 front axle with these thrust washers for the last 20 years or so, there doesn't seem to be any more endfloat of the stub axle than when I put it together -I do regularly grease the kingpins though. I think that most of the exceptional heavy wear on bits of our cars will have occurred during the long period of them being just unloved "old bangers" which only received maintenance when something fell off; especially so in the years immediately before the MOT test was introduced.
01-12-2017, 04:46 PM
(01-12-2017, 01:23 PM)Stuart Giles Wrote:(30-11-2017, 06:23 PM)Dennis Nicholas Wrote: Would phosphor bronze thrusts wear the axle faces or would they just wear out themselves? Thanks Stuart. Looks like phosphor bronze to use. Just got to find a 1 1/6 (7mm) cutter to clean up the recessed face under the end of the axle beam. The one I had made to do the grinding is 1 1/4 in dia. - good for the 3 other faces. Perhaps I will just pluck up courage and try and turn it down smaller Dennis
02-12-2017, 11:48 AM
[quote pid='4144' dateline='1512143218']
Thanks Stuart. Looks like phosphor bronze to use. Just got to find a 1 1/6 (7mm) cutter to clean up the recessed face under the end of the axle beam. The one I had made to do the grinding is 1 1/4 in dia. - good for the 3 other faces. Perhaps I will just pluck up courage and try and turn it down smaller Dennis [/quote] Whoops should have read 1 1/16 inch (27mm) cutter. |
