05-02-2020, 12:21 PM (This post was last modified: 05-02-2020, 12:22 PM by Mark McKibbin.)
When did the Oil Button appear as my late '27 Chummy does not have one unless it went where the dash lamp is situated or the hole was welded up in an earlier resto. Photo attached.
(05-02-2020, 12:21 PM)Mark McKibbin Wrote: When did the Oil Button appear as my late '27 Chummy does not have one unless it went where the dash lamp is situated or the hole was welded up in an earlier resto. Photo attached.
Mark,
The dashboard has a Lucas SM5 switchboard for a coil engine - should have a Lucas SM3 switchboard for a magneto engine.
It looks to have the 1929 on large patent plate, as noted mounted too high, instead of the small patent plate normally fitted in 1927
Yes the car has a coil engine so the switch assembly is that type, attached is a picture with plate removed. There is no sign of a repair so either it never had one (unlikely) or the car has been fitted with a reproduction dash when it was restored in the '80's. Does anyone have a photo of the correct button for 1927 as I will fit one for appearances and get a shorter patent plate.
06-02-2020, 01:21 AM (This post was last modified: 06-02-2020, 01:21 AM by Rick F.)
Can't help with a photo, but the early and late working parts of the button are interchangeable - the fixing ring (early) and the two-hole flange (late) just screw onto to the body.
