DOOR LATCH ?? WHAT CAR
Hi All, Does anyone know what car these door catches come from?
Many Thanks Rob RPM
They don’t look exactly the same (the top bit with ball on is different) but they look like Mk1 Ruby. The difference being they a have a ball where my Ruby catches have a hole to fit the chain for opening the lock.
John Mason
I don't think they are Austin, the deign details aren't Longbridge style.
Thanks, guys, I was hoping that I could convert them for my Nippy, but like you, Mike I'm not sure they are from the Austin range.
I have now bought the correct latches for the car.
Regards Rob
They are Wilmot Breedon latches, I can't tell you what make of car exactly as they appear to have been used on more than one. Although similar to Nippy items is some ways I am not sure you will find them suitable, I had a couple of pair when I made some new Nippy latches thinking that some parts would be useful, in the end I did not use anything from them.
Hi Ian, that was my thoughts in the end, thinking that I could work them into a pair of Nippy type latches. However, Willie Mckenzie just had a batch of original style made, so bought them instead. He did say that he wouldn't be having another batch made once all sold with only few pairs left , so I think this is the last chance saloon for anyone still wanting the correct look re the 65 and Nippy interior door latches.
RPM
Rosengarts are fitted with a very similar set up.
