14-08-2017, 10:31 AM
I have a Makita 240v right angle drill, which I inherited from a friend. I suspect he bought it at Mackays of Cambridge. It is single speed, and I feel that variable speed would be a great improvement.
Front çrank bearing lip replacement
18-08-2017, 01:53 PM
Back where we were two weeks ago with an adaption of what is suggested in the Woodrow , only partly my take on it.
18-08-2017, 01:55 PM
That's the way to do it - nice work Derek!
19-08-2017, 05:47 PM
I
A stripped down block becomes an excellent parallel. It was the only way to get enough head room to drill out for the set screws. Hole was started will a drill and completed with a mill
19-08-2017, 06:42 PM
19-08-2017, 09:22 PM
(19-08-2017, 05:47 PM)Derek Sheldon Wrote: I Hello Derek, now confused, 1st picture shows holes being drilled from inside, this picture shows being drilled from outside. In the past I have drilled through the 4 1/4 whit holes with the tapping size drill, then tapped right the way through, easier than tapping from inside. Your finished job looks excellent, I like the use of the A7 block as a parallel.
19-08-2017, 10:18 PM
(This post was last modified: 20-08-2017, 08:39 AM by Derek Sheldon.)
Now there is a story to be told. Having gone through the procedure previously and posting pictures I was told by a well respected contributor to this forum that it was likely to fail , he has had several to which he was aware of. I was advised todrill right through and use either 1/4" or 6mm high tensile counter sunk set screws. That is exactly what I done but turned up a new retaining disc as shown.
20-08-2017, 08:46 AM
Zetomagneto, this is the previous finished job. Looks good but as I said it is reported to fail. Eight times 3/16"X 3/4" whit set screws and loctite
20-08-2017, 12:45 PM
(20-08-2017, 08:46 AM)Derek Sheldon Wrote: Zetomagneto, this is the previous finished job. Looks good but as I said it is reported to fail. Eight times 3/16"X 3/4" whit set screws and loctiteHi Derek I would be interested to know why this would be likely to fail.Usually numerous small fasteners are stronger than a lesser amount of big fasteners.
20-08-2017, 04:35 PM
Will take another pic tomorrow showing complete set up
