05-04-2019, 02:49 AM
This will be a challenge to figure whats where , about 95% done , don't have all hoses correct color yet for function ..
bantam turbo
05-04-2019, 06:33 AM
Crikey! Where is the engine ? Looks like a heart by-pass operation without stopping the car.
BobH
05-04-2019, 10:07 AM
HI Steve,
Looking Great, when Do you hope to have the first Run. Colin NZ
05-04-2019, 07:56 PM
Where is the radiator mounted now? That looks like the intercooler in the radiator shell and the water hoses go off into the firewall?
Simon
06-04-2019, 12:04 AM
YES , no radiator , water tank behind driver , water pump near tank .. water from tank in 3/4" hose , return 5/8" to give resistance to flow .. Water also goes to turbo for cooling and to rear of block at valve area .. wATER FROM TURBO RETURNS TO (Y) FITTING .. More pics coming .. STEVE
06-04-2019, 08:40 AM
Looks great. Is that an oil pressure accumulator in the bottom of the first and second photos -just wondered what the thinking is if so?
06-04-2019, 02:31 PM
Hadley crank / rods ,, oil press. from gear internal pump comes out rear oil line joining oil from electric Nascar Differential pump under large RED Nascar oil screen (100 micron) filter plumbed from ali. pan (sump) together go to crank feed (cut off screw on filter timing cover) with T fitting going to oil gauge to get reading of crank feed oil pressure (most important) ... One front oil feed goes to Turbo and back down to oil breather tube , second front oil feed goes to valve chamber cover and center cam bushing . I turn elect. pump on to prime engine before start up . STEVE
23-05-2019, 04:42 AM
28-12-2019, 09:30 PM
Well the Bantam with Austin 7 engine is still doing fine , ran at Bonneville Salt Flats with 82 MPH . Still won't pull 3rd and 4th gear yet , so working on new cam profile with 112 / 114 lobe split to be built . Going to alcohol next year so will step up injectors to 55# .. There some other updates in the works , oil line reroute , maybe water entering head first , it goes in at 2 spots on head plus front and back of block on port side .. Head gasket is now solid copper , seals better and reusable , block to crankcase gasket steel and reusable . There are 2 studs from bottom of block to top of crankcase on cam side to help secure they stay together STEVE
<p><br></p>
28-12-2019, 09:54 PM
HI STEVE,
Sounds like it"s coming on Fine, What thickness Is the steel gasket Between block and crankcase Also are you using a locked diff Very well thought out and good workman ship. Cheers Colin NZ |
