Changed plans (we've nearly all been there...)
Changed plans -
[Image: changed-plans.jpg]
Love the cat mascot.
Tony.
Shaved his beard off to save weight in the same way you used to lower the level of your Chummies back axle oil it seems Tony G?
(23-12-2019, 06:29 PM)Ian Dunford Wrote: Shaved his beard off to save weight in the same way you used to lower the level of your Chummies back axle oil it seems Tony G?
'twas only a rumour Ian that I used a teaspoon full of 3-in-1 (it was actually two).
