Thank you all for the words of praise. Still no finder's of the anomaly?
Should be a lock washer between the gland nut and the locking nut.
Number sequence?
Well spotted Chris, but that's not the anomaly.
Robert
Would that hub just happen to have 4 wheel studs?
 The stud holes seem a bit close together.
Peter
The spacing seems more like 5 stud to me?
Here's a clue.
Different base plate diameter?
Hi Robert
Is flange on the pinion shaft is for a UJ propshaft, (not sure what it’s from). The other is the standard Cardenas block flange?
  Hello Howard,
  yes it's a Ruby flange, screwcut and with a new gland nut fitted to enable a Ruby propshaft to be fitted to an early 1928 axle.
Users browsing this thread: Colin Reed, Nick Salmon, 17 Guest(s)
