Does anyone have the dimensions for ruby Mk2 door check straps
i have a picture but dimensions would make things easier when trying to re make them
Thank you
Car type: 1929 AD Tourer, 1930 Rosengart LR2, Rosengart LR4 Van 1938 APE Tourer (Opal)
I believe that Mk11 Ruby’s did not have check straps but a metal apparatus on the bottom adjacent to the A post.
Hi thanks for replys
Yes that is the part I have a picture of just wondered if anyone had the dimensions save a lot of guess work
when it comes to making them
Thanks
Graham
If noone else has before I get home, I'll take some measurements. Do you have the steel plate fixed to the door, or do you need dimensions for that too?
Thanks Nick that would be great both parts please as
All I have is a picture at the moment
Nick thanks that is just what i needed
thank you very much for you time
Regards
Graham
This is what you need.
But I never seem to get the time to do the brazing?
Tony
[attachment=8261]
