Not long ago I acquired a couple of 4-speed crash gearboxes, one of which had a fabric-joint propshaft still attached. The trunnion end is badly corroded, but being from a lwb car the shaft could easily be shortened for use in a swb. The block on the end which houses the pin would have to be rebuilt though. I can imagine several ways one might go about this but have doubts about strength / durability. Does anyone have practical experience of 're-making' the lump on the tail end of the propshaft?
The 'why' is very simple Tony - I don't want to toss another original Austin Seven part in the hedge if it is known that this can be fixed...
And also why I've fitted an A7 Components Hardy-Spicer shaft.
Much less vibration as well, vibro-massage through the seat gone!
All the above understood and appreciated gents - indeed I have had a (shortened) Hardy Spicer shaft in my own car for many years.
