Car type: Austin Seven RP 1932
Hi Folks, can anyone tell me if the original battery box (on a Dec 1932 RP Box Saloon), was a complete box.
My 6V Battery is sitting on a strap about 25m/m wide, welded under the drivers seat, with a Bungee Strap
securing it. (Obviously not original). There are indications that an original box may have been cut away
during previous restoration work.
Apart from this, there is one hell of draft coming through the hole. Help.
Thanks for your input Martin, I had thought of getting a new box but am unsure whether it would drop into the existing
hole without fouling the chassis member.
20-11-2017, 09:48 PM
(This post was last modified: 20-11-2017, 09:50 PM by Andy Bennett.)
My 33 RP has a full box which slots in from the inside with 'flaps' welded to the floor. Others I have seen have the same.
It is a snug fit for the battery and without venturing out to check have not noticed it as an interference fit with the chassis.
There was one on ebay a little while ago. If you don't have fabrication facilities then I am sure one of our bodywork cherished suppliers must offer them.
Andy
Good morning. Somewhere I have an original RP battery box and rather than being folded up from one sheet it is two pieces with four folds - two lips which overlap the floor and the base folds. This must have saved Austins material by not cutting out a cruciform shape or tessellating many on one sheet.
Stuart
