Dripping Zenith 26va
13-11-2019, 08:27 PM
Looks like the wrong spring has been fitted. The original spring should look like to new spring (on the right of your photo) but of lighter gauge wire.
The one on the right is the spring from the old pump....
I need a spring like the one on the left only lighter gauge, any body help me ?? Thanks Andrew
13-11-2019, 09:52 PM
(This post was last modified: 13-11-2019, 09:52 PM by David Stepney.)
Sorry, I meant on the LEFT of your photo. Oops! The one on the right is clearly wrong.
16-11-2019, 05:28 PM
Hi Andrew,
Following on from my replies to your AC fuel pump gasket problem, I now see the reason why you're unable to swap over the two main springs shown above - it's because the main springs in both fuel pumps you have are incompatible with one anther. Your old existing pump is obviously an 'M' Type pump which used a smaller diameter spring as shown on the right, the new pump you bought from the Seven Workshop is a 'T' Type pump which used a wider diameter spring as shown on the left. The way to resolve this would be to buy a second hand but original NOT a modern repro one 'T' Type pump, remove the main spring from that and put it in your new Seven Workshop 'T' Type pump. Jeff. |
Users browsing this thread: 22 Guest(s)
