6V wiring...
What is it called, John......how to find on eBay? Sounds ideal. Thanks!
This is the same item from the Green Spark Plug Company.
https://www.gsparkplug.com/disconnect-ty...older.html
I think this excellent green knob (ooh Matron) switch is for a negative earth battery ?
An earlier post indicated positive earth ??
Although- shouldn't a 33 Seven be  negative earth ???
You can get them in different colours Red I think for positive battery terminal and also done with black knob.
John Mason
