08-10-2019, 09:23 PM
Indicators
09-10-2019, 09:25 AM
I did my own on my Ruby as I wanted the semaphore indicators to work together with the flashing ones. I also wanted them to work from the switch on the steering wheel hub. This required relays to make them work and two flasher units one for off and one for near side. I also incorporated hazard flashing lights. These are to be absolutely correct not legal as both sides flash independent of one another and you get an effect of one side on and the other off so they flash side to side. It is however much more noticeable than four lights all flashing together.
John Mason
10-10-2019, 09:41 AM
Although not strictly required I've always fitted side repeaters on the cars I've built using Royal Enfield pilot lights as the view from the side through a spoked wheel can be obscured.
https://www.ebay.co.uk/itm/Clear-Pilot-L...3942668738. They are ridiculously cheap but the chrome on the escutcheons leaves something to be desired...
15-10-2019, 09:27 PM
