02-10-2019, 08:08 AM
Whilst on the topic of manifolds from pipe fittings on my RP with SU I tried a manifold like the original but from two galvanised pipe ebows all brazed on. But althugh internally more like a Nippy manifold it seemed no improvement on the narrow passage standard. At over 1 inch probably too big for a little modified car.
Presumably the manifold never gets red hot as it stayed together.
Something like the above using early manifold better although moves air cleaner out towrd bonnet.
