Well, mines not like that but wouldn’t like to say which is correct.
This is normal for the early cars - hence two lengths of hub screws.
Most modern cars omit the screws ( if a wheel comes off, so does the brake drum. With hydraulic brakes instead of s setscrews they fit twin circuit braking.) All the hole locations have to be very accurate, so convenient to omit.
Many thanks for the replies. Very helpful.
And I think the blanked-off holes in the drums are for the wheel-locating dowels, which you don't have either.
Do your wheels have plain, circular wheel-stud holes?
