Starter Motor Rebuild Interchangeability
I have a recollection that you can use the main body and field windings from a later forward facing motor to rebuild an earlier rear facing type (post bacon slicer, of course.)
Am I correct? If so I'll go and find a tired later starter...
Thanks
Charles
You would need to reverse the field connections otherwise it will turn the wrong way
(01-09-2019, 10:20 PM)Zetomagneto Wrote: You would need to reverse the field connections otherwise it will turn the wrong way
Thanks
The alternative is to adapt a modern starter (a la Wosp type) to make a spare.
Not that hard, I imagine, if you select the right Denso one to adapt
Charles
Golf TDI goes the right direction and is internally geared so more compact than wasp.
I think you have to reposition the brushes on the end plate to change the direction of rotation.
I'm sure there was an article by Ray Moses on exactly this topic either in the Bristol club newsletter or one of the downloadable Hereford club newsletters. I'm away from home at the moment else I'd look for it.
Mark
Thanks very much for the pointer.
Google leads me to the Bristol Club who have this excellent technical article
http://www.ba7c.org/pdf/technicalDocumen...929-32.pdf
Perfect!
Charles
