Helical gear for oil pump
I am looking for a good oil pump drive gear, are they available from cherished suppliers?
I have looked but not seen any advertised.
It’s for a 1933 RP but I guess they are all the same..
Roger
I have a good spare.pm me
Roger - these are readily available and, almost always, in good condition.
Happy to send you one for the cost of the postage.
Yes they survive well, I have a lot of them, but not as many as Rory
Thank you both for your replies, I will send pm Ruairidh.
The crankcase and cam shaft are totally corroded beyond use, I did remove the oil pump but the gear I needed was worn/corroded on one side, I have plenty of pumps though.
Roger
