Bonnet latches
I am looking for bonnet catches for a 1934 RP saloon .I can buy new latches that attach to the front wings but I need the pieces that are attached to the bonnet .I will be at beaulieu so can collect if you have any.
Tony Betts and a few others who can be bothered to save them from damaged bonnets have the rivet-on pieces which have the "finger pull"... only available as secondhand.
Check the hook ends because they get quite weak.
Thanks I will contact Tony to see if he can help
