16-07-2019, 11:42 AM
(This post was last modified: 16-07-2019, 11:42 AM by Biddlecombe.)
My RN is fitted with a switch located just behind drivers right ear and a corner roof light. Lamp not working before I start stripping things out can anyone suggest a wiring route that it may have please. Nothing in Woodrow.
I have traced some old wiring and am happy to use the length from the switch to the lamp as is in situ, but I need to run new wire from live source to switch, I can find a route but my question is where do I source the live feed from in order that I can isolate the lamp when I switch engine off and secondly what gauge of wire should I use for my 6 volt system. Grateful for all help as electrics is my least of all best subject !!!
Peter
I expect your lightbulb is 6 watts or less.
6 watts at 6 volts is 1 amp.
It is always good to overspecify cable when only 6 volts available, so the 5 amp cable out of an old table lamp or similar will do.
I always distrust the body as a means of earth return, so I would use twin wire, one live to the bulb from the switch, one back to an earthing point which itself is connected back to the battery.
Thanks for that but can you help me with where I pick up the live from please? I want it to isolate when I switch the engine off.
Peter
A tortuous route, but under the headlining, down the inside of the door pillar, out by the dash and into the back of the ignition switch - same terminal as the coil, or you could connect onto the cutout/regulator under the bonnet. The hardest bit is threading the wire. Just as a thought, (as my RN has a vacuum wiper), I think there is a switched live on the windscreen wiper circuit ??
With a problem like that I would use a "chocolate block" type terminal block.
One piece of copper solid wire connecting two or three teminals together, with a "tail" to the switch, and the other wires with little paper labels for i/d into the other side of the block.
Very non-vintage, but easy to use and not bullet connectors, which I do not like.
In Austin Seven terms and time chocolate block connectors are ultra high technology.
John Mason
