21-07-2019, 07:05 AM
Well done Colin, would be interested in the results of fitting the side panels also. Then we can knock this on the head.
Ruby-Opal-Pearl radiator deflector
21-07-2019, 10:13 AM
Hopefully, adding the side baffles will show some effect - I'll have a go when I get a chance and report back.
Colin
21-07-2019, 08:24 PM
Added the side panels this evening and blocked any gaps with Bluetac/duct tape to ensure that the air couldn't escape around the sides or base of the radiator. Peak temperature seen when running at 40mph was 95 degrees C. (This occurred when travelling east and held steady.) Then removed all three air deflectors and did the same run again. Peak temperature seen this time flickered between 95 and 96 degrees. Ambient air temperature was 21 for both runs.
So, from this short test, it looks as if the additional cooling effect from having the side and bottom deflectors in place was less than 1 degree C. Colin
22-07-2019, 04:01 PM
Thanks Colin
24-07-2019, 01:14 AM
Colin's suggestion that the mystery panel may have been meant for Export models is commendable. Only problem :- of the dozens of Rubys I restored or part/restored here in Oz over the years (and I had 3 of my own), I've never seen one. Most of those Rubys also had the side deflectors missing, which prompted me to make a swag for our Club. But the general concensus was they didn't make any noticeable difference when fitted anyway. Perhaps the conditions weren't severe enough here as our Mountains are only Hills compared with Europe's. Very interesting. Thanks for the photos and descriptions - it's good to learn something new each day Cheers, Bill in Oz
27-07-2019, 04:16 PM
Two times £1.80 for Toolstation aluminium 6x9” louvres , three cans of spray paint from Halfords £23 and a spare bonnet that’s been in storage for thirty years. Touring bonnet.
28-07-2019, 11:38 AM
On the Berlin trip some years ago my Ruby had the side deflectors in place, and I occasionally suffered fuel vaporisation. It seemed to me that those who did not have side deflectors did not have the problem. I conclude that the air reaching the carburettor is cooler if some of it has bypassed the radiator. In my many years of Ruby ownership it only became a problem as petrol was modified to a more volatile mixture.
Robert Leigh
26-08-2019, 01:18 PM
(This post was last modified: 26-08-2019, 01:19 PM by Derek Sheldon.)
OYes Fully tested cooling system, four blade fan, louvred bonnet, radiator side flitch plates.
35degrees climbing Swiss mountain passes
28-06-2024, 03:24 PM
Oh I love the Louvered hood idea. I have a spare hood too. Maybe I’ll do the same. Temps here in Nj peaking out about 30-35 C. My Austin is always Boiling. Now I’m having second thoughts about the baffles. Maybe that wee water pump from Australia that I read about?
28-06-2024, 04:08 PM
Similar temps here in the south of France in the summer. My RP with 4 blade fan, good original radiator and cleaned out block never boils.
