19-07-2019, 06:33 PM
Would appreciate some guidance on rigging sealed beams to a new dipswitch.
Conductors from lamps are coloured blue/red, blue/white & black. These are linked directly to the panel switch (coloured blue). Multimeter records current at each headlamp termination concurrently.
Dipswitch has three terminals. As each headlamp appears to be wired independently (off side not powered from nearside as per original wiring diagram) then how should these be hooked up to the dipswitch?
Any assistance gratefully received. Thanks.
