14-07-2019, 11:16 AM
Perzackly. If Chris has found a work-around I'd be delighted to hear about it!
The following warnings occurred: | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Chris Blakey - Celebrate the Seven Trans Siberian journey
14-07-2019, 06:07 PM
14-07-2019, 07:43 PM
ooooooh - that is interesting.
15-07-2019, 05:16 PM
(This post was last modified: 15-07-2019, 05:17 PM by Ruairidh Dunford.)
17-07-2019, 08:33 AM
17-07-2019, 08:41 AM
I have tried to leave a comment directly on their blog but cannot get through the posting procedure.
If you are reading this, Chris, Helen, and Arthur, good luck in your exciting adventure. Safe driving!
17-07-2019, 12:07 PM
Perhaps I'm a bit behind the times, but I wish it was only my petrol pump which leaked oil!
It has once or twice occurred to me though that if I didn't 'consume' oil I could increase my luggage space by a gallon or so when touring... I'm not in touch with Chris either but if he's having any trouble by the time he reaches St. Petersburg I have contacts there who might be prevailed upon for assistance. Can also suggest a decent hotel if the Hull experience repeats itself!
17-07-2019, 01:58 PM
As I have said elsewhere I am experimenting with silicon gaskets wherever I can use them. Including replacing some fibre washers.
The car is not perfectly oil tight, but not far off it. Coincidentally, I also have a leak apparently coming from the petrol pump area. I think a new silicon gasket has fixed it, not sure yet.
17-07-2019, 02:11 PM
The pumps normally leak from the arm shaft - wears the pump body.
17-07-2019, 02:12 PM
