Speedo drive for 1927 Chummy
I need a new drive from the gearbox to the speedometer of my 1927 Austin 7 Chummy. It looks as though the recommended length is about 15 inches.
However, if I fit one one of this length which goes straight from the gearbox to the speedo, it will interfere with the movement of the fairly short gear lever and make gear changing almost impossible.
Any advice would be gratefully received.
Roger give David Cochrane (A7 Components) a ring
01788 522033.
J
