02-11-2017, 10:49 PM
Hi, is it possible to service the rear Dampers/Shockers on the RPÂ without removing the assy from the car, ??
RP box rear dampers.
02-11-2017, 11:05 PM
(02-11-2017, 10:49 PM)Smiley Wrote: Hi, is it possible to service the rear Dampers/Shockers on the RPÂ without removing the assy from the car, ??I'm not sure why you would consider not removing them from the car. You need to check not just the discs, centre bush etc at the front but the link bush at the rear. Easy to remove and much easier to fettle on the bench.
03-11-2017, 10:52 PM
Point taken Chris. Thanks.
