31-05-2019, 09:26 AM
Does anyone have a failed cutout? I am looking for one which I can pull to pieces and use the case to mask a solid state device.
Regards,
Jamie.
Regards,
Jamie.
Dynamo Cut Out
Regards, Jamie.
31-05-2019, 10:52 AM
might be a good idea to say which type is suitable for your car/age...
31-05-2019, 01:19 PM
It is for a Ruby, but the model does not really matter. I just want a period looking case.
03-06-2019, 08:29 PM
Do you mean the regulator / cut out and fusebox unit that sits on the bulkhead?
If so, I may have one if I can find the upper cover.
Geoff.
Yes, that is the device: the cut out which stops the battery from over-charging. It does not need to work. Thank you Jamie.
06-06-2019, 10:01 AM
I've definitely got one where the cutout is corroded and most likely non-funtional. I need to find the upper cover though which isn't with it, but I think I have somewhere. I need to clear the garage up this evening so hopefully I'll find it.
Geoff
06-06-2019, 12:47 PM
Geoff.
That would be perfect. I could pull it pieces without worrying about ruining something that works well. Thank you.
06-06-2019, 11:43 PM
That would be ideal. How much would you want for it?
Jamie.
07-06-2019, 01:27 PM
I've sent you a PM.
