Exploded Views
Does anyone know of a thread showing an exploded view of the RP body panels around the sill and running board area. Confused
An exploded diagram would certainly be of interest, but the response so far is not promising.
The detail of gusset piece is perhaps elusive. It is in the form of a large shaped overlay patch extending to bottom of the sill and from the forward end of the triangle and covering all the area of B pillar and inner mudguard as appears as double thickness in the restoration photo. From the rear cross member back the body functions much as a unitary one and the gusset assists support. Off hand I am not sure of the detail within the door posts. Hopefully someone can oblige.
