HI STEVE,
First off looking very neat and a credit to your ability
How do you run in to get every thing to bed in
also what max revs will you set
When will the first run be
Colin
NZ
The engine easily turns 7000 in 1st & 2nd , not so in 3 &4 , thats why turbo and fuel injection .. First race meet is June 9 at El Mirage Dry Lake , north of Los Angeles , California .. A 1 mile run for top speed with shut down distance .. I take engine apart every year to check everything and upgrade . . This year it was better locating crank and bearings , 2 studs from bottom of crankcase to bottom of block on valve side , upgrade block studs , solid metal block to case gasket / spacer , mill head to dead flat ,.008 .. And all this turbo/fuel injection , intercooler , water tank in back , bigger ECU , more wiring , a lap top for tuning , new paint !! Nothing particular on run in , the tuning and short spurts on a street . The rings and bearings have been there awhile .. STEVE
Hi Steve I, and I am sure others, would be fascinated to see (and hear) a video of it when you run it up in anger, let us know how it goes and what figures you get at El Mirage please.
Don't just show us pictures, bring the machine over to Pendine Sands on 15th/16th June, then numbers of us can turn up in slightly more conventional Sevens and shake your hand, before hearing and watching it perform.
wicked piece of work. I have a few curiosity questions.
What is your current compression ratio.
What is the peak boost pressure.
What RPM does the boost start to kick in.
Are you chasing any speed records?
Compression about 7 1/2 , haven't measured it with latest gaskets , beginning tune stage , boost about 5-7 # , start rpm to be determined , car runs as Time Only , Roadster class based on Ford body sizes , 4 PLAY to small .. STEVE
