12-03-2019, 06:16 PM
![JPEG Image .jpeg](https://www.austinsevenfriends.co.uk/forum/images/attachtypes/image.png)
Spent a couple of hours making a template
and then a steel split toeboard after adjusting the pedal fits to be free from obstructions and rubbing against stuff.
Used 3 captive caged nuts rivetted to the bottom half of the drivers toeboard. Makes taking out the floor a lot easier.
I should really fit the seat squabs to see if my feet can now manage to work the pedals....
Brake pedal travel , not finally adjusted, is limited to just 1” which is great and what I’d hoped for. Haven’t fitted the clutch spring yet.
So can now proceed to the handbrake set up and the fitting of the carburettor its connections to the throttle pedal and choke.
Also can reset the steering column levers and linkages
Regards
Bill G
