  • 28 Vote(s) - 3.32 Average
First trial fitting of my new Ulster exhaust manifold. So far, so good. The choke was a challenge but I managed to get it such that I get full choke without it fouling the manifold.
.jpg   20190222_143221.jpg (Size: 23.3 KB / Downloads: 463)
.jpg   20190222_144429.jpg (Size: 18.88 KB / Downloads: 463)
.jpg   20190222_152245.jpg (Size: 19.14 KB / Downloads: 463)
.jpg   20190222_152256.jpg (Size: 18.88 KB / Downloads: 464)
Nice manifold, who did that one?
I dont get it Steve. The manifold in the picture isn't the same as the one fitted to the engine? The bend on n°4 is different.
It is, Bruce. It's just the angle of the photo that makes it look different.
Made by Ryan Edwards at Bicester.
HThat’s nice - did you take the car there to get it done or are they off the shelf?
No. Bespoke made using my previous manifold as a pattern to set the critical dimensions. He also had my carb and inlet manifold. When I collected it on Wednesday he was doing an exhaust for a mid '70's BMW 635 CSL (a Batmobile). Unbelievable work.
http://www.reexhaustfabs.co.uk/
Here you are, Bruce. Proof it's the same manifold!!
.jpg   20190223_141325.jpg (Size: 16.77 KB / Downloads: 253)
I quite like such sporty things (isn't that a John Barlowe inlet manifold??) and I don't really don't want to be the Killjoy but have you or haven't you fitted a heat shield??? If not you might consider one as the exhaust manifold now seems to be quite a nice 'rechaud' for the fuel……
No, no heat shield. This manifold replace one that's been in place since I built the car in 2013 and that has since done 5 full seasons of Hill Climbs and Sprints, usually double entered (the equivalent of 55 events in total), together with a fair bit of road mileage each year with no fuel issues so far.
Be interesting to see what the difference is from an improved manifold.
And I can see your lambda sensor boss, so you're getting serious....
C
Users browsing this thread: 57 Guest(s)
