Dynamo no go
#31
No progress yet Dave
(05-02-2019, 01:00 PM)Dave Wortley Wrote: Tiger,
My drill is 3000rev/min max so say 2000. I must have let it run for 3 or 4 mins. Hope it works for you.
Cheers,
Dave.
My recent rebuilds of C35M dynamos support Dave's suggestion of 2000+ rpm for a few minutes. This allows sufficient voltage to be  generated in the field windings to generate a strong magnetic field. You will feel the resistance to the drill as it starts to generate its full output.
Tried 2500 rpm for 5 minutes.
Still no go
Tim
(09-02-2019, 01:32 PM)Tiger Wrote: Tried 2500 rpm for 5 minutes.
Still no go
Tim
Have you considered taking it all to a reputable Auto Electrician !
I agree Tony. There is only so much you can do on the forum. It would be different if we had the Dynamo on the bench in front of us.
John Mason.
