16-01-2019, 09:41 PM
Try Peugeot 205 valves.
Over 4" long, 7mm stem, available from about 29mm to 40mm+
C
C
Valve Data
Over 4" long, 7mm stem, available from about 29mm to 40mm+ C
17-01-2019, 08:41 PM
Thanks Charles,
hadn't considered going French. Is a Austin/Morris 1300 longer than a a Mini/Minor?
17-01-2019, 09:40 PM
Hope you don't mind me adding.
If you need longer springs to fit. I have a large quantity of ULSTER & GRASSHOPPER valve springs. Tony.
18-01-2019, 12:26 AM
(17-01-2019, 08:41 PM)Robert Foreman Wrote: Thanks Charles, The Peugeot valve is very handy for many old vehicles because it's long enough to shorten to fit many different cars. I do remember that A Series valves came in different lengths for different specs, but not massively different. C |
