01-01-2019, 02:26 PM
(This post was last modified: 01-01-2019, 02:45 PM by Andy Bennett.)
Hi everyone
In wishing you a Happy New Year, mine has not started well.
I have 1933 Box running coil ignition, standard dynamo, with Accuspark distributor.
Having not run the car for some time I started her up yesterday with no problems.
This morning on getting ready for our New year day run, she turned over and then after a revolution almost stopped with a resistance and then turned over again, but did not start. This repeated. There was no backfire or clear misfire but it felt like she was trying to fire at the wrong point causing the ‘stopping’ of the engine.
Just to state that there was plenty of fuel.
I started working through the ignition. There was apparently no spark when holding lead off the plug or against decent earth.
Rotor was turning.
I changed the coil for a new one (not tested). This time the engine span freely with no ‘stopping’ but would still not start and no spark seen when removing a lead and putting lead close to plug.
It then briefly half ran as if on only 1 cylinder and really struggling.
I then replaced it with the original coil I took off about 8 years ago and which was working fine when last used. This time the tightening/stopping came back but still no spark.
I then took the Accuspark distributor off and replaced with the Bosch (again was fine when removed). Would not start, but when I played around with a lead on a head stud I saw a very faint spark. I could almost convince myself that I did not see it, but it was definitely there. But it was not enough to show any signs of starting. Tried new condenser, no change. Points opening fine.
There was 6V on the coil terminal with ignition on.
So I decided to stop there and think a while.
I realised that there was no discharge showing on the ammeter with ignition switch on. At rest ammeter was at 0A. When I put the lights on discharge was about 5A.
Looking at old posts on here it suggest that discharge with ignition on but not running should be around 6A. I should know, but I couldn’t say what it usually is, but not 0.
So is this my problem, whilst I have 6V from ignition at the coil, I have no current to drive it?
If so, where has it ‘gone’? The ignition switch clearly works to the extent that it supplies 6V to coil and switches the lights on and off.
Appreciate thoughts on whether or not I am on the right lines/looking at the right place (ignition switch, cut out?) and if so what the problem might be in the apparent resistance or breakdown and how I might hunt it down.
Appreciate thoughts from a very frustrated (non) driver for what would have been a lovely New Year run.
Andy
Rotor was turning.
Andy
