Revitalising Plated Fittings
Does anyone have any suggestions for revitalising the finish on plated fittings, such as door handles, other than replating, replacing or living with them?
Regards,
Jamie.
I use an ultrasonic cleaner - works wonders.
(28-12-2018, 07:50 PM)Ruairidh Dunford Wrote: I use an ultrasonic cleaner - works wonders.
Any suggestions on make/model, Ruairidh?
Thank you for the suggestion. How do you protect the surface afterwards, assuming that the pits are fairly deep?
Regards,
Jamie.
I bought a nickel stripping and plating kit
and used it to refurbish instrument rims, handles , screws etc.
There’s a thread on this forum , under AllAlloyCup and plating
If you need more info just use the search tool above for
“Nickel plating” round about Sept 2017
Bill G
Martin - the one I have is big enough to take a crankcase, with heating element etc. If you send me what you want to clean I will do so and send it back to you.
Jamie - I use metal polish and put it back on the car/s, so far, so good.
Bill and Ruairidh,
Thank you both.
Jamie.
If you want parts cleaned up Jamie - PM me and I will happily help you too.
Ruairidh,
Thank you.l That is much appreciated.
Kind regards,
Jamie.
(28-12-2018, 08:50 PM)Ruairidh Dunford Wrote: Martin - the one I have is big enough to take a crankcase, with heating element etc.  If you send me what you want to clean I will do so and send it back to you.
Ruairidh,
What solvent do you use in the ultrasonic cleaner?
Andrew
