31 Back axle required
Hi,
I need a 1931 back axle , have a 29 in at present but need to change CWP to 5.67
For Chummy Tourer based special.
I can be emailed : richnash@yahoo.com
Dicky,
the newly manufactured 5.67 c/w is a smaller diameter than the original one and you should be able to get one to fit your existing back axle casing.
(22-12-2018, 10:03 AM)Ruairidh Dunford Wrote: Dicky,
Thanks for that, the problem is down to the pinion side of things, the pinion bearings and torque tube are a slightly different design, the driveshafts are also slightly larger diameter, so will hopefully be more suited for trials use in the future.. Smile
