I have an ignition/gas plate which is wobbly on '29 car.
I can see it has a bolt to tighten it to clamp something, but I've just realised that the thing it will clamp to is the outer stator tube, which of course needs to move. There is room for some brass shim (which stops the wobbliness), but I imagine the ignition plate must be held in place otherwise there will be no fixed register position for the levers.
This is a cobbled together project prior to me so I don't know what I'm missing, but I'm scratching my head how and what it can fasten on to. (The next bit down is the nut holding the steering wheel.)
Has anyone got a photo on file from sorting something themselves that might throw some light please?!
thanks Jon
I think the inner tube which now ends at the steering wheel nut (and doesnt turn when the steering wheel turns) must have originally been longer to permit the fastening of the ignition plate? Is this a part which requires splitting the steering box to replace?
thanks Jon
