King pin?
Hello All
I wonder if someone called advise me please.
I have just stripped my kingpins on a Mk 11 Ruby axle and have discovered that
one has a hole all the way through the pin and the other one is sealed at the bottom.
Both have the threaded hole at the top but I was wondering which one is correct please.
Thank you for your time
Graham.
The King Pins should be threaded at the top, blind at the bottom and with a small hole bored in the side at the bottom to enable lubrication of the bottom bush.
Many thanks indeed for that Steve.
