Nickel Plating Service
.jpg   IMG_1447.JPG (Size: 68.04 KB / Downloads: 181)
If the nickel plated parts on your car need re-plated,
I can bring them back to looking bright and shiny.
Parts must be brass, or steel based and no larger than 5" square.
So far I have had good success with instrument rims and cases,
Door handles, bonnet catches, badges , control levers and rods,
Side lamp cases and rims, mirror frames etc.
Sorry but I can't do Radiator shells , or windscreen frames.
I don't think I can do headlamp shells, but perhaps rims?
If required I can strip off old chrome, or nickel prior to
polishing and re-Plating in bright nickel. See image above.
Replated parts can be dulled by light abrasion with steel wool or fine scotchbrite.
Please note I cannot do chrome plating or plate Mazak.
If you have parts needing attention please message me by email
with a photo of the parts you want restored. If parts need de-bumped or
Soldered please have that done before you send them.
Each job quoted individually, turnaround time 2-3 weeks.
Bill Gardner ( aka AllAlloyCup )
