Diaphragm clutch
I am interested in using a modern diapragm clutch and would be interested to hear comments from those who have gone down that route.
Thanks in anticipation, Gene
I seen to remember a few of the 750 racers used a modern clutch and saved a huge amount of rotational mass. The flywheel can be vastly lightened
This is also on my list of things to play with.
It could give a softer clutch action.
The problem is finding a cover plate that will pass over the nose of the gearbox.
Any 750 formula racers out there.
You won't find diaphragm clutch that will clear the g/box nose you have to shorten it and make a release bearing adapter see photos.
     Terry.
flywheel  for Renault clutch.
Great pics,
Thanks for posting them.
Which renault clutch cover is it ?
Its time to find my scrap gearbox parts and play on the lathe.
Cheers Richard
(01-12-2018, 09:03 PM)dickie65 Wrote: I seen to remember a few of the 750 racers used a modern clutch and saved a huge amount of rotational mass.  The flywheel can be vastly lightened
Hi Terry, thanks for photos. Your car, and the component parts thereof are truly a credit to your engineering skills and dedication.
All the best Gene
The clutch kit is for a Renault 4 and early 5 with 845cc engine. QH part no QKT 136 AF used this kit for the last 10yrs it makes a great
hillclimb/sprint/race clutch but is a bit to switchy for the road as you are operating it directly, and needs careful setting up but completely
 reliable for 5000rpm drop the clutch starts.
(03-12-2018, 12:44 AM)Terrytuned Wrote: The clutch kit is for a Renault 4 and early 5 with 845cc engine. QH part no QKT 136 AF used this kit for the last 10yrs it makes a great
So what's the total weight of that flywheel and clutch assembly Terry?
Thanks
Charles
Weight of clutch flywheel assy: about ten and a half lbs, less than half the weight of a std assy.
Terry.
(03-12-2018, 11:05 AM)Terrytuned Wrote: Weight of clutch flywheel assy: about ten and a half lbs, less than half the weight of a std assy.
Terry.
Thanks
For anyone who wants to try a diaphragm clutch I am posting drawings using the Renault clutch kit there may be a more modern cover
   available but I have only used the Renault kit.
Terry.
